Stainless Steel Braided Brake Lines
Morning all my question is above really i bought a set of the brake lines a while ago went to get them fitted and was told it would be 200, 45 for each wheel then 20 for brake fluid is it worth doing it for 200? I know the gains are small right ??
Would it make that much of a difference??
It doesn't make a huge difference that I've noticed
Sent from my SM-G900F using Ford OC mobile app
ok is it worth it tho 200 is abit steep to me
Diy dude. 200 is a lot for that. Just watch a YouTube vidtorial. Quite easy just long.
Sent from my SM-N9005 using Ford OC mobile app
cheers ive watched them just not too sure aha
I'm not sure lol I only paid £90 for mine in total
Ok ill see about having a bash at it what can go wrong lol
Apart from the visual impact, the braided hoses aren't any more efficient than the ordinary ones. As for £200 for fitting them, that's way over the top. Should take about 5 minutes per wheel to replace the hoses. A quick bleed maybe a flush if the system hasn't been done for a couple of years. Work takes about an hour on a garage ramp, I'd pay no more than Beccacat paid, if I were giving it to a local garage to do.
Personally, the job is a piece of cake, as long as you bleed the system carefully, you can do it in a couple of hours on the drive, jacking up each side as you go.
ive rented a ramp for £15 an hour on monday on my day off so will hopfully get the hoses and the exhaust fitted, plus get to use all the tools in the garage, will be fun :)
