Fiesta Mk7.5 Dashboard Assembly
Hi
Can anyone tell me how many bolts/screws hold the dash board assembly in place and where are they?
The reason is because I've recently got my car back from a Ford Body Shop and apart from a few issues that need to be put right, I've just noticed that the trim on the drivers side windscreen pillar has a clear visible 1/4" gap at the base where it meets the dash board.
And the small bit of grey trim that lies immediately inside the quarter light windows has a large gap between it's inside edge where butts up to the dash board and is also on the same level as the dash board itself. (it should be lower that the dash board and I think that the inner edge of that trim should fit underneath the edge of the dash board hence, the large gap.
I should have mentioned that the damage was to the front offside wing and the offside corner of the bumper assembly and the quarter lights was removed for painting and I think that the cause of the problems above is because the dash board has somehow dropped about a 1/4".
I hope that the dash has 'dropped', & nothing worse.
But the body shop should sort it out as part of the repair.
