Engine Change
hi all I'm changing the engine in my van as i hydro-locked the old one the new engine has come with the ecu, clocks and two keys. will my ignition barrel be coded to my previous ecu?
thanks in advance
Dan
Why u have new ecu an clocks is it different type engine
No same type engine. Injectors were damaged and I was told the were definitely coded.
I would just take numbers Down off injectors an put new engine in an drive it most likely they be fine if worst comes worst u could get recoded cheap enough
Oh really. Okies. Thanks for your help
