Roof Leak,access To Antenna?
Noticed a little patch of water on the drivers seat and a drip from the roof light,put my hand behind the roof lining near the front window and it's a bit damp but not a lot,I assume you remove the entire overhead light and there will be the antenna behind it.
How do I get the light unit out?
i normally use a flat blade screwdriver to prise it out from the windscreen side.
