Best Way To Clean Seats?
ive noticed that someone has dropped something on the passenger seat which has stained it a bit, pretty !Removed! off about it! ive tryed cleaning them with some fabric cleaner, it looks clean for a day then comes back through! anyone know the best way to clean them?
A carpet cleaner like a vax or a bissell with the separate upholstery attachment is probably your best bet you might be able to hire one if you dont have one , just be careful not to overwet your seats
Then once clean put some scotch guard or supaguard on them to protect them.
Vanish carpet cleaning foam. Works. Every time.
Sent from my SM-N9005 using Ford OC mobile app
Have you any idea what might have caused the stain.
im gonna guess it was some kind of sauce from a mcdonalds, as it was just after someone ate one in the car
Autoglym have an interior cleaner for carpets and seats coupled with a upholstery brush and warm soapy water with a Hoover should work without anything expensive being needed also agree as above once clean get some supaguard to help provent staining etc
Try using Cybergold stain remover (google). This is what we use on carpets to spot clean them. Sauce's will contain sugar and colouring which will be tricky to remove. Hoover is a good idea. Only use white kitchen roll, nothing with a pattern. Don't rub, just blot
I used this to remove Drambuie from my Lounge carpet with great success.
Vanish foam, and use the persons face as an applicator tool
i looked in my local tesco for the vanish foam and had no luck, wheres the best place to get it?
Tesco, it just comes in a pink can with pink lid and has a brush under the cap. Amy supermarket stocks it.
my local tesco extra didnt have it, I'll try asda or morrisons!
In Tesco it's not with all the vanish products, it's with the floor cleaners. (Tesco employee :-) )
got hold of some of this, gonna give it a go when im home later!
