Rear Pads On 2001 Focus
Hi, I have a 2001 focus hatch, 1.8. I need to change the rear pads and I need to get the rewind tool to push back the caliper, but what I'm not sure on is, do the calipers rewind clockwise or anticlock, and would that be on both side? many thanks
Clockwise both sides.
Remember to spray around the piston with some wd40 (so you dont rip the rubber)
Sent from my GT-I9505 using Ford OC mobile app
thank you admin for your valuable input, and yes good point made regards to spraying wd40, , many thanks
No problem :)
Its easier with a rewind tool but you can do it without one if you have to. I use a G clamp and a pair of mole grips.
