Battery Removal
Hi Can someone please help me!!
I have a Focus Titanium 1.6 Ti-VCT 2006 and need some advice on how to remove and replace the battery. Some stupid design flaw on this model places the battery underneath the top front air grill, and the Air Filter housing next to it. There seems to be no easy way of removing the battery unless you take the whole engine bay apart.
If anybody could give me some assistance this would be appreciated immensely.
Hi Gary, should be more simple than that. Basically the battery box (plastics surrounding it) can be removed. You need to unhook the clips and firmly pull the battery box away from the battery, then when its removed, you can just pull the battery out through the front, reinstall the battery, then reconnect the plastics.
If you have the battery securing bar over the top that will need to be removed first by undoing the 8mm nuts either side.
Excellent Thank you for the advice James will give it a go.
no worries, I know this is how my MK1 CMAX was, and that was the same pretty much as the Focus, but it shouldnt be too different
Hi James thought I'd let you know job done....Thanks again for you help, was easier then I thought lol!!
Sent from my SM-N9005 using Ford OC mobile app
you will need your radio code if you do this :)
Glad to see you got it solved! was it as easy as just tug and replace?
Pretty much yeah!!!
Result!
Glad to be of service :)
