Rear N/s Indicator Problem
Has anyone had problems with the nearside rear indicators - I have replaced the bulb but it still does not work - I also tried two other bulbs at the same time - still no luck - I also disconnected the electrical connection to see if there was any problem there - but none seemed apparent - the other rear lights are working perfectly on that side
Any help gratefully received
Hi Roger, check the indicator earth is present and that the housing isnt damaged / corroded.
