Abs Light After Pad Change
Hi guys changed pads on gf fiesta last weekend. Since the ABS light has lit up constant and notice only part of the disc is being touched. Would these 2 things be related? And how would I reset ABS warning on dash.
Check you've got the correct pads in.
Found out the rear bearing trash which caused abs light. New bearing and abs sensor ring
