Removing Fiesta Mk6 Boot Handle?
Does anyone have any idea how to remove the boot handle on a MK6 fiesta? Looking to replace it but have no idea how to get it off. There is one nut to the left hand side once you remove the interior trim, but then it still feels like it's attached at two other points. Both of which I have no idea how to get at.
I'm talking about the following bit:
http://www.fordpartsuk.com/shop/ford_fiesta_mk6_tailgate_handle_primed_f_1381026.htm
  • 3 years later...
Just thought I'd answer this since I couldn't find a guide when I searched.
I have a mk6.5 and it's pretty simple.
Open you boot
Remove the negative connector on the battery
Remove the three phillips screws on to boot trim (inside)
Pull the trim from a corner and work your way around to remove the clips
Remove the trim
Remove the three (10mm) nuts, one is in the middle and hidden slightly.
Close the boot down halfway
Remove the torx screw holding in the license plate lights
Remove the positive and negative crimps on the inside of the lights
It should come off with a slight pull
Hope this helps, any questions just ask.
