Rear Lights.
i need to change a rear bulb on my mk6 fezza and i have tried so many screw drivers and allen keys and none of them are working.
does anyone have any ideas what tool i need to get to remove them?
is it only 2 screws and the rear screw i need to undo to remove the lights or is it not that simple ?
thanks
Hey i changed my rear brake light last week on my 05 fiesta, its just the 2 screws between the light and the rubber of the boot and the wing nut in the back underneath the carpet, all you need is a star screwdriver but the 1 with the 6 points on it, not sure what the actual name for it is once the screws are out and you have the wing nut off you just need to pull because there is a rubber gromet that goes from the back of the light through the metal of the car, hope this helps you.
let me know,
Steve
let me know,
Steve
do i have to pull hard, im scared of braking it.
that worked perfectly .. thanks alot. really appreciate it. :)
