No Volume!
Hi guys,The volume button on the steering wheel and on the dash stops working sometimes.I can start the car and it works fine,but when i turn the engine off for a short while and then start it again the volume dosen't work,has this happened to anyone else?Many thanks :)
Well that can't be right . . .
I've had something similar where you'll start the car and the radio stops working and doesn't start again unless you either change modes or switch off and try again.
It's a random occurrence but very annoying.
I've also experienced radio failure when the door's been opened and a message appears on the computer. The method above restores that too.
Weird but it's only happened about three times and every time I've managed to get it working so far......... :blink:
Its really weird,when im listening to a cd i can change the track on the steering wheel,but not the volume! :angry:
Now that is weird--something not quite right there or a gremlin in your radio........ :blink:
Ive not experienced that but I have had a couple of times where ive turned the radio off (normally as im parking it away in the garage at night) and although it shows as off on the computer screen, it actually continues to play for about 10 seconds = spooky
