Remote Central Locking Not Working
My remote central locking stopped yesterday all of a sudden. I have replaced the bty but still nothing, any help would be appreciated
you may well have to reprogram the remote key to the car again.
when the battery goes flat or when its replaced you only have a short time to replace it before it loses its memory.
Thanks for reply, ive done all that where u turn key to the II position x4 times it beeps then take key out press a button on fob that beeps. But when I try the central locking there's nowt!!!
Check the circuit board on the fob, as sometimes it's a damaged connection causing it.
agreed, if you have a spare with the remote, program this in and test it, if neither work then you should start by checking fuses. If that doesnt work you need to check the wiring, or it could be the remote module in the headlining of the car.
Don't take the key out!
Turn key from I to II 4 times, leave ignition in position I while you press any button on key and you should hear a chime to confirm key is synced. Wait 30 seconds or remove key, should now work. If not then either the circuit board in key is broken or a wiring/motor/fuse problem.
