Blower, Heated Screen And Screen Wash Not Working
I have a 2007 Focus CC. The heater blower, heated windscreen and and windscreen wash have all stopped working. I also have a bonnet open warning on the dash. The fuses appear OK. Is there anything that is common between all these? Any help greatly appreciated.
Solved by troy45
  • Solution
It'd be worth checking all the electrical connections to the GEM unit are secure - this is the module on the passenger side under the glovebox which also contains a large number of fuses.
As above they are all on different fuses so cant see it being a fuse issue
Found a loose connection exactly where suggested, Many thanks troy45 and artscot79.
Glad it was an easy fix for you B)
