I Have A Problem With My Keyfob And Carnt Open My Boot
My key has decided it doesn't want to work anymore I can unlock the car with the key but how do I get in my boot help
Could fold down the rear seat if you need something out of the boot asap.
Tried to reprogramming my key to get it to work and it doesn't want to know
I must be stuck had hand but out carnt get open boot without my keyfob
What car is it so will it not open from key or boot handle
change the battery in fob thats astart
Probably the same as mine (2.5) my blister switch doesn't work either. It's been swapped but still only opens with the key.
2 guys at work have the same problem, not sure if they have also wasted money trying to replace the switch.
I'm worried about this happening to me.
I have swooped the battery still nothing and my boot doesn't have a lock or button to open it try the handle won't open its a 2005 tdci sport I just need use of the boot and carn't get in thanks for the comments x
  • 3 weeks later...
its most likely the microswitch in the remote fob for the boot. If the boot still opens by pressing the boot release / rubber switch. If its just the remote, you have two options: 1) buy a replacement fob, just swap the immobiliser chip, then program to the car or 2) buy an aftermarket switch for about £14 off ebay, and use this remote to unlock the car / boot, then just use the key to drive.
try disconnecting the car battery for 10-20mins and reconnecting it.
strangely one day i had an issue where the central locking completely stopped working, i changed the battery in the fob and it made no difference. it started working again when i reconnected the car battery
