Fiesta Mk7.5 Interior Light
I noticed that the interior light is not working, clearly the bulb has gone. Will this be covered under warranty as the car is under a year old?
However, also tempted to do this myself if it is a simple task. Anyone know how I get into the bulb as cant see any clips on the diffuser / cover.
Bulbs are easy to change, what model have you got? Profile picture looks like a blue ST.
Which light isn't working? Front light the clear lens just need spring off with your fingers, it uses a 38mm festoon bulb, the rear light needs the whole fitting pulling down and uses a T10/W5W bulb.
The owners manual shows you how to change bulbs.
Bulbs won't be covered under warranty, if all the interior lights aren't working then it may need taking to the dealer.
Yes the blue ST :)
Its the main one that comes on when you open the door, stop the car etc. Reading lights both work as does the one in the back.
In that case it's how I said in my earlier post, once you have the bulb it'll take a couple of minutes tops.
