Power Problem
Hi all im having intermittent power drop off when accelerating and vibrations from underside of car when this happens and hearing increased noise from the rear exhaust section could this be a problem with the exhaust manifold or a valve problem mk6 fiesta
Im having the same problem lack if power, had no ecceleration last weekend called aa out gave me a list of codes, said it was a valve and an injecter, its been in the garage all week cost a bomb, drove it this morning still not much power when you put your foot down also sounds like air blowing from somewhere, if I put my foot to the floor when changing gear theses not much there at all, so its back to the garage on monday.
I had a problem very similar to this on a volvo s60. Turned out the intercooler had a crack in it and this was affecting the air mixture entering the engine. It was low on power and was shoving a lot of more soot out the back (was a Diesel). Might be worth asking them to check this? The intermittent problem sounds like it might be something else though.
