Wanted - Mondeo Mk4 2008 - Headlight Plug Fitment
WANTED
FORD MONDEO MK4 2008
HEADLIGHT PLUG FITMENT
DRIVERS SIDE
HALOGEN, DIRECTIONAL TYPE
SEE PICS ATTACHED
post-38737-0-00647200-1422802814_thumb.j
post-38737-0-66938000-1422802820_thumb.j
By fitment do you mean you need a new plug, or need to know which wires go where?
Pin-out will be in the wiring diagram if you can get hold of a copy.
On the other hand if you need a new connector, locking tab snapped off etc a replacement connector would be something like this
http://autoconnectors.trustpass.alibaba.com/product/115582972-101847511/6X0973717_14_Way_Sealed_Female_Connector_1_5_mm_2_row_Coding_I_neutral_6X0_973_717_6X0_973_717_6X0973717_42125300.html
You could google the part number to find one from a supplier bit closer to home
Yes a new plug needed as mine water damaged beyond repair. Tried every scrapyard in the area and nothing doing.
  • 5 years later...
Hi
I’m in need off replacement plugs but that link no longer shows the plugs.
Does anyone know where I could order some for both drivers and passenger side for Halogen Adaptive headlights ?
  • 6 months later...
hi I’ve just joined the site and have the same problem! Did you manage to source replacement plugs at all ? If so where from please
  • 7 months later...
Hi
I need to replace a broken wire from headlight plug on MONDEO MK4 2007 Titanium X. It has pulled out from pin inside plug. How do you get this plug apart to insert new pin with wire which I have.
Hi, normally, the pins have a barb on them so that you push the pin in from the back and the barb prevents the pin from coming out again. Is that not the case with yours? Usually, to remove the pin you use a pin extractor or something to bend the barb straight so that the pin can be slid back out...  that's all I know... 🤔
