Abs Brakes.
Hi guys.
Quick question.how do I know if my abs is working or not.
Try braking hard on wet grass or gravel?
You'll usually get an ABS warning light if there's anything wrong with the system, plus you get that slight grinding noise at around 10-15mph when you first drive off as the system does a self-test
Ok thank you..
As above or find a quiet road. Get to 30mph and slam brakes and clutch down as you would in an emergency. The brake pedal will start bouncing if its working.
Thanks JohnH will give it a try.
