Focus Battery Light
Hi all
i recently put a reconditioned alternator into my 2009 focus diesel and since then the battery light comes on when i start it up in the the morning and stays on for about 2 mins then goes off but today it came on and stayed on for about 10 mins there is is loss of power to the car and i have checked the connections to the alternator and the battery all is good,can anyone shed some light on this problem please.
tks alan
first is why did you replace alternator, what issues did you have
hi Ian ,
i changed the alternator because the brand new battery i just bought kept going flat and i was told the alternator was the problem as soon as i put it in problem solved till about 2 wks ago when the light started coming on
alan
Also, what brand of alternator? there are some horrible makes out there..
Hi
unfortunately i dont know know the make of alternator it was but i got it from a reputable auto electrical seller and he matched it to the old one from the car while i was standing in front of him and as far as i know they were the same make .would it cause a problem if it is a different make ?
alan
could a number of things, unlucky with alternator faulty, wiring issues, pcm fault
can only check proerly with a multimeter
Check the 3 wire connector that comes from the alternator. Mine corroded near the pcm and caused the light to come on.
As above , known for corroded wiring anywhere between 3 pin plug and pcm
Hi
alan
Eurocarparts and RTX alternator???
Google RTX alternator and you will find lots of examples of the same fault.
This is the very reason I asked what brand of alternator. RTX are absolute rubbish. I don't know why ECP are still trying to sell them!
