Mk3 Parking Sensors
the parking sensors have just failed on my mk3 it says malfunction servive req , is this a simply fix i.e fuse or is this a garage thing
thanks
Are they clean? that can throw errors (especially mud on inside)
Early Focus MK3 versions suffered from water ingress into the connectors of the PDC sensors which could cause problems. Diagnostics of the system could point you in the right direction. A defective sensor for example will generate a DTC code in the Parking Assistance Module (PAM).
Depending how handy you are you could try to remove the sensors one at a time, clean them (especially the connectors) and reinstall them.
