Drivers Door Misaligned?
Hi guys, my drivers door isn't in line, when im at higher speeds you get a fair bit of noise from it and when I was on the dual carriageway a few weeks back and the wind caused the car to be a little wobbly.
Is there something I can adjust/do at home or is this a garage job?
Is it the door or the mirror surround come loose and the wind hitting that reason I say is my near side one has come out a bit and I get wind noise off that just haven't got round to sorting it yet
Checked and they look to be ok, I did notice a few marks where the door is slightly scraping on the car though (very slightly)
On an unrelated subject I was cleaning the car and and tidying it up a bit and whilst checking for errors have found these;
EPS C1956-30
IC U1900-60
GEM P0071-0F
I have google'd for what they mean however wanted to know whether these will become a problem for the car, are they anything to worry about?
Where is the drivers door out of line?
If it's at the b-pillar there is scope to adjust it via the metal striker bolted to the b-pillar, you'd loosen the torx fixings then use a mallet to adjust it's position then re-tighten.
Its on the hinge side of the door, when the door is closed its outwards slightly.
