Diagnostics
Is there a diagnostic port on my Focus Mk1 CL , and if so , where can I find it ???
Look under the steering wheel for an oval panel.
Pull that off and the port is underneath.
post-28494-0-78806000-1426674475_thumb.j
Thanks Clive . Cheers
Clive , hello again , is there any particular Scanner you would recommend for my Focus , There are so many ?
You should be able to use any obd based kit however as the mk1 Focus is obdI (not the currently used obdII) features are a bit limited.
