Car Alarm
Over the last week or so the alarm on my 2010 Ford Focus 1.6tdci keeps randomly going off.. I would be happy if the alarm could be removed but have been informed by ford that is goes through the ecu so can not be removed from the car.. I can't seem to find any problems anywhere.. Has anybody else had the same problem and found a fix for there problem I could try... My neighbours would be pleased lol thanks
sounds like one of the sensors is playing up
do you have a fault reader
Nah I ant got a fault reader but think I might invest in one because ford want to charge £54 an hour to investigate the problem ....
over on the FFoc there are some guys in the midlands that have the ELM27 set up, this software runs off a laptop and with the correct cable connects to you car and fault reads amongst other things
Need a code reader that reads bcmii codes , the alarm triggers are stored in the bcmii ,unusual for alarm to play up on your age of car, you sure the tailgate is not unlocking its self. Thats common.
I read somewhere that the bonnet latch maybe to blame. Just an idea
I heard of that and is one of the things I need to look into.. Thanks for the reply...
ELMConfig will tell you what triggers the alarm the last 5 times iirc.
You would also be able to deactivate it (at least the siren if not fully) with that software.
So it's been to a ford specialist today and they reckon it's caused by the aftermarket stereo I recently had fitted possible voltage drop.. Anybody know how this could be fixed...?
Sounds like Ford just wanted to blame the one thing that's not theirs... :lol:
The stereo does come on and go off with the ignition yes? If so, shouldn't be any problem.
Do you have a multimeter? If so, test the battery voltage when the alarm goes off.
Yea the stereo goes off and on like the stock stereo.. I will check battery the next time it goes off....
My focus will lock with the bonnet/boot open, and not set the alarm off if they're shut/reopened whilst it's still locked. All your door locks/lock brackets are secure and not loose?
