Water/coolant
Losing water/coolant,head gasket is ok no cracks or leaks anywhere new cap new thermostat,it's boiling over when I do 70-80mph any ideas thanks
Have you done a compression test to confirm the HG is fine?
Also check around the water pump and heater matrix
Water pump???? If its not circulating the coolant it will boil at speed
