Front Fog Lights.
Hi everyone. I bought front fogs for my mk2 focus a while back. So I thought it's time to get them up and running. I checked the fuse box and the fuses are all there. So is it a case of just getting a new box with the fog light switch on it plug it in wire up the fogs and away I go ? Or do I need to do other stuff ?
Usually the wiring to the fogs is all there so in most cases you just need the light switch with fogs option if you look behind the from bumper you may find the plugs are there all taped up
Yeh I've found 2 plugs coming of the left hand wireing loom that goes into the main headlamp one is slightly corroded cos I found it with no cover. If pics are needed id be happy to show you
Hi, you may need to have the gem programed to get hem to work, its ford they use the same wiring loom for all mk2 variants, I have had the same problem with heated windscreen and spotlights spent loads of money at ford trying to get my mk2 reprogramed. in the end I was told to hard wire them, so I did, and they work just fine, it took a long time to workout the wiring for the heated screen the spots was easy..
Yeh I think it's a case of get a new switch with the foglight button then just wire them up
