Mk2 Focus Front Speaker Change
Swapping out the stock component speakers for some aftermarket ones but need some advice on the wiring. I know on some cars you can tap into the original wiring on the factory speakers straight into the cross over. But looking at the speakers in my focus I can see 4 wires going into the woofer ?!?! Question is can I use any of these wires, if so which or alternitavly best/easiest way to get the wire from my door to the head unit without drilling holes?
I believe that 1 pair of wires is fed on to the stock tweeters.
So 2 wires from stereo to speaker then from speaker 2 wires go back and up the door to the tweeter
Do would it be possible to tap into the wire running from the stereo that being the case?
Yes is the simple answer
