Mk2 Air Con Question
Odd one guys when stationary the air con blows warm occasionally cool. However when driving the air con starts blowing cold. Any ideas it's a MK2 2006 1.8TDCI thanks very much
whens the last time it has been filled with AC gas?
I'm sure it was only a year or so ago. Additional info I notice that the radiator fan does not come on at all. Should this be kicking in with the aircon the fan does not even come on after along drive
yes the fan would come on if the AC has been turned on. I would get it checked if it has leaked gas or needs a re-fill first before doing anything else
air con gas will be ok as you say it blows cold when moving, the fan is not working then, needs looking in to, check fuses , relays etc
Fuse looks burned but it's screwed on how do I get it out. Looks hard wired in
