Fluid Leak
Hi guys have a black fluid leaking from engine just behind my driver side front wheel just had my oil sump tray done and ive had a leak ever since but it doesnt appear to be losing oil had a leak on the intercooler pipes but changed them and its stil leaking any ideas what the leak could be??
Could well be from the pan from experience I know the old cvh engine oil pans used to be notorious to get sealed correctly I,e that's why there's a tightening sequence or could be from your crank seal .try cleaning around that area and see if you can spot it after a short run .
Will do thanx
