Broken Map Sensor Vacuum Pipe
Does any one know the replacement part number for the broken vac pipe in the photo plz... and how urgent is it to repair?? thanks for any help
post-45522-0-12990100-1429526857_thumb.j
sorry 1.8 tdci 55 plate
Cant you cut it clean and reconnect it and bind with a bit of tape.
its an option as a temp measure but no idea if i will get codes thrown at me lol, only caught the flippin thing with a rag :(
:) if you do the temp repair it will not throw a code
having a look at epoxy fix for now ... and plasters for the 10000 cuts getting the pipe of lmao
cheers ;)
The only code i see on the pipe itself is "4M5Q 9S428-AA" but that brings up squat :(
looks like the pipe in the diagram below, im not sure if it can be sold seperately
finis codes is either 1338678 or 1352477
post-39336-0-48876800-1429536242_thumb.p
yeah its the bottom pipe of the 3 above the bracket and screw no code so it looks like it cant be bought seprate, which is a sod as it means 25 quid at least for a piece of plastic pipe 6 inches long.
typical ford lol
thanks for that by the way Nexus
best option is to get the pipe from a scrapyard if you have one not too far
