Focus Mk2 Cigarette Lighter
My cigarette lighter has fell in the whole any idea how to get it back out
Pop out the plastic cap on the panel next to your clutch pedal and remove the screw with a Torx screwdriver.
Pull the panel off and you will be able to find the socket hanging down.
It looks like the seating ring around the socket has broken or else the socket would be quite firmly in position.
The plastic ring would I assume have been a black non-illuminated one however there is a cable taped to the socket wiring which when attached to an illuminated ring will light it up (red and green available) which looks better than the blank black one.
I have a spare green illuminated one, if you want it just PM me your postal details, no charge as it is now surplus to my requirements.
To mount the socket you put the ring into the hole first from the front , next slide the socket in from the front as well ensuring you line up the grooves.
Connect the power cables and illumination wire from behind and job done.
post-28494-0-56269600-1429727042_thumb.j
I have fished it out and there was a black plastic thing broke up and thank you for the offer will pm you now
I'll have one of those green rings out to you in a couple of days.
Between work and gearing up for my new car tomorrow I'm a bit tight for time but should be able to sort ot out on saturday for you.
Yeah that's fine you have more exciting things to do first I will have a St as soon as insurance will allow
I bet they are I know I would be haha
They all want test drives, you can guess what the answer was to that :d
Sure can or you could start to charge them for a test drive
Now that's a darn good idea :)
£100 per hour is my charge ! :)
Sounds good.
I could recoup my years insurance in a very short time :)
Sounds a great plan am sure they would still line up for a go
Nobody from the Traffic Unit will be allowed though, they can't drive for toffee ;)
Just give them a few lessons haha
ooooo, nice Clive, whats happening to the previous focus?
Chopping it in for part-ex.
It will be Vosper's property by 4pm tomorrow.
