Rear Wiper
Hi everyone,probably been done to death but noticed my rear wiper isn't returning to its proper position.Works ok,until I switch it off then everything goes pear shaped.Not good on electrics,can someone point me in the right direction?Thanks.
Most likely the relay in the passenger fusebox but could also be a fractured wire inside the rubber boot between body and tailgate.
Thanks for that,I will check it out.
My old fiesta had this. The wiper wouldn't return to the correct position when switched off then just failed completely. The motor was badly corroded and knackered so replaced with a 2nd hand part for £20 and now all good again.
