Lift And Tilt
Hi,everyone,bought a mini lift secondhand without instructions.Is it ok to lift the car with the sill seam running along and sitting on the lifting rubber pad.If not I will have to lift pass the sill and from the car floor.Any ideas?
i use a pad on my jack and lift from the sill, if that helps. i have a groove cut out on the pad so it sits properly and doesnt bend the sill.
Is it just Ford cars that has a raised seam?Its a real pain.
Buy jacking pucks.
They have a slot to accommodate the seams.
Thank you for some ideas I will look into it.
