Noisy Tappets On Mk 1 1.4 Cl
Top end is noisy !!. Has anybody used Wynns oil additive to solve this problem . At the next service , will use Magnatec with the Wynns . Any comments please Woolyford
What's the mileage? That engine has shim adjustment and I think the valve clearances should be checked at 100k miles.
This engine does not have hydraulic tappets so the wynns treatment will not solve this problem at all.
This engine has solid tappets which as said can be adjusted with shims. It is recommended to check/adjust the valve lash at the same time the timing belt is changed. This is because all parts are easy accessible at that time.
