2013 St Wheels Onto A 2013 Titanium...
I've managed to source some ST wheels, that are in mint condition. They're from a 2013 ST, and i'm wondering if they would be a straight for onto my 2013 Titanium? I already have the 17" 8-spoke alloys on her at the moment, but to be honest i've also liked the ST wheels (plus I can swap and change them when I fancy it)
I'm pretty much thinking that they will fit, but I thought i'd ask... as someone else might have already swapped their wheels?
post-62796-0-77654600-1430631385_thumb.j
Solved by MarksST
  • Solution
They'll be fine they are the same size and ET.
Thanks, I thought that might be the case. But i'd rather check, just to be certain.
Post some pics up when they are on, im after some st wheels atm for my Titanium
If u sell ur others wheels let me know as I'm interested. Cheers
  • 3 weeks later...
they are the same tyre size so no need to change any mechanicals just get em on!
Just check you don't get any arch rubbing on full lock, if you do then rack limiters may be necessary.
I'm pretty sure my 2015 ST with 18's has limiters as the turning circle is bigger than a standard focus.
18" wheels? Is there room for any rubber? God help your back.
I'm looking for a cheap set of 15's.
I didn't get these in the end, as they were based in Essex - i'm based in Bristol. It was almost a 3 hour drive there, and 3 back. Lol!
Have them on a standard zetec and lowered on eibach 30mm with no problem at all.
post-48119-0-82745400-1432226880_thumb.j
Hi regie so ur wheels don't rub the arch liner on full lock as I might get a set of 17s and did u tell ur insurance company about ur upgarde? Cheers mate
No rubbing or not that i have noticed, even dropped it 45mm before but the ride was terrible. Mods declared.
post-48119-0-46008300-1432240544_thumb.j
