Tyre Pressures
Hi, So many different views on tyre pressures. I.ve had from 30 to 33psi, 33 to 35psi and 34 to 36psi depending on load on my Zetec 1.6 petrol. Is there a definate answer, understand they have to be done cold.
there is a sticker under the door on the drivers side that will tell you the correct pressures
I have the same car as you.
Personally, for me the sticker pressures are a bit on the low/conservative side. I used to do 32 PSI on all four (when tyres warm), which was OK, but last time I increased it to 33 PSI (on Stoney's recommendation). The ride is a bit bumpier, but on the positive side it seems that there is better body control, and the car seems to coast ever so slightly better. All in all I am happy with it at the moment.
So the answer is somewhat down to personal opinion.
