Brake Pads
I have a ford focus 1.8 zetec its a 08 I was just wondering are the rear brake pads the same as the front or is there a difference my rear ones are worn and can hear them when driving
The rear pads are different, also the pistons need rewound back into the calipers.
Thank you stef for that
and if you can hear them them then its discs as well.
Thank you Ian
and can someone point out to me what pads i would need to get as cant find manual that came with car and the noise is only happening on 1 side so im hoping i could just replace that disc but i will replace both pads just to be safe
Discs and pads should always be replaed in axle sets.
Put your reg into Eurocarparts website or go to your local motor factors - they will be able to supply you with the right pads/discs
