Engine Management Light Has Come On
Can some one please tell me what I have broken here and how much it would cost to repair
post-65704-0-23045400-1432070406_thumb.j
Looks like just the pipe has broken, you can either get a replacement one from ford and fit that or take the broken bit of pipe out of the rubber and push the okay piece in and see if it holds, after this it will probably need the fault codes erasing failing it goes away on its own and then just try it! Good luck!
