Mondeo V6 water comin out of the header tank please help
AUG 23 2009 TIME 17:52
:( I've got a p reg mondeo V6 when my engine gets hot after runnin the water pushes its self out of the header tank when the top is screwed down tight i cant work it out can someone please help
thanks very much for your help
FITZY
i presume the seal on the cap and the pressure valve are sound. it sounds like your cooling system is pressurizing above its normal level. this is one sign of a failed head gasket are there any signs of white smoke or steam from the exhaust? you need to pop to a local garage and get them to probe the expansion tank for signs of fumes. if this is ok then you can look for other causes to the problem.
Thank you mintalkin i will look into tht
