Heavy Knock/ Pop Noise After New Clutch Fitted !!!! 51 Plate
Hi, hope someone can help with an annoying issue.
Recently had a new 3 part clutch fitted. Upon start up is a heavy knock/pop noise.
I took the car back to the garage, they climbed all over it and they couldn't find the source of the knock.
When I turn the key to start, as soon as it fires up, there is a loud 'pop' 'knock' noise.
It then sometimes does it when I put it into reverse and start moving. The knock seems louder in the car than outside.
In the car it seems to be within the driver's side area, from gear lever to door.... from seat to pedals.
This happens every time the car is started, if I sit in it and turn it on and off a few times, it will without fail do it upon starting.
Hope someone can help.
Regards
check the gearbox mount
Hi, I will have a look.
Cheers
