Seatbelt Chime
Can anyone tell me why my seatbelt chime and light comes on when accelerating or cornering left it's very annoying Thanks! It's a 2009 focus zetec 1.8 petrol 3 door
Check the wiring connector under the seat.
Could be that as you move in the seat it pulls a bit.
Or paseenger seat ocupancy playing up, try plugging in passenger seatbelt in and try again
It's not the passenger seat I've checked that it also happens when I lift my !Removed! off seat with seat belt plugged in. I'm wondering if it's the pressure sensor but don't understand why it does it when belt is plugged in surely it shouldn't make a difference wether I'm sat there or not when it's plugged in. Thanks
That was suppose to say lift my bum off seat but obviously a s s was not allowed ha
You have answered your own question there then, seat belt switch .
Ok thanks I'll look at getting it changed
Part of the seat belt catch, but as clive said check the wiring under seat to the catch incase wiring chaffing.
white and brown wires i think for drivers buckle switch, be aware this circuit goes directly to restrants control module
Ok thanks iantt I'll check them at some point today and if all is good I'll get new switch
Cheers everyone I've fixed it! It turned out to be a poor connection from the plug to the pressure sensor wire!
