Front Brake
I'm going to replace the pads on my wife's 2008 1.3 fusion this Friday. I did the pads on my 2006 C Max few weeks ago.
my question is, is it a normal bolt to remove the calliper or like the C Max a recessed hex head bolt?
thanks in advance
You will need a 7mm hex key to remove the caliper guide pins.
I watched a video where the bloke removed the entire calliper from the mounting bracket.
If I can't find a 7mm I will attempt to do it the other way
Took the entire Calliper off in the end, two 14mm bolts.
I decided to do the discs as I'd left the pads a little longer than I should have and they were starting to grind.
Discs are a lot cheaper than I thought so why not
Biggest pain was actually getting the back pad into the piston!
