Remap
it says the box can take 280nm of torque
Should be ok then :)
YEAH ! :-) all good news. Now I only need £200 :D
DV6TED4 isn't so bad assuming its looked after, spend a bucket load on preventative maintenance and youll save shed loads there after.
Course ill know better in the future. No more PSA engines here!
Can't find any rating information on my car I refuse to get a remap until I know everything will be okay.
It's always sensible to research the torque limits of one's gearbox & clutch first, however the best companies should always be conservative with their remapped outputs (up to + 20% bhp / torque is generally considered safe ) without hardware changes
What's your engine Ryan??
It comes up as
Engine: 1.6L Duratorq CR TC (115PS) - DV6 Transmission: 6 Speed Manual Trans - B6
If that helps :)
is it 16V version ??
Remaps are in 3 stages. Stage one is only done by software.
Once you approach the garage they will tell you what they can offer.
Remember that they did many engines in a past and they would do anything that could damage your engine.
If your engine is 16V you only get 6% in bhp and 7% in torque.
Not sure but it's a turbo diesel TDCI
No, I'm pretty sure by 2012 it's the 8v 1.6 TDCi. You also have a DPF which hamper the remap. Don't take this the wrong way but you'll be best off asking some reputable remapping companies for advice on your car. :)
100% dpf fitted and it's the ceramic type so no eloys fill ups required at least.
Superchips can get me to 130BHP and 314nm torque, A garage close by very good company which mainly works on mini coopers have done a few Focus's in the past with great results say 147BHP and 324NM torque with 12 month guarantee.
Thanks for all your help now going ahead with researching how much it can take :)
