Tyre Pressure Sensors - Help
Hi, I've just bought a new set if wheels and had them fitted. ( they put the old tyres on the new wheels)
The problem I've got is the sensor light keeps coming up on the dash as they say that I need a new valve to put the sensors in on the new wheels.
Where can I get these valves? The sensors can be reused? Cheers
1.) Make sure all tires are inflated to the vehicle’s recommended inflation pressures (found in the owner’s manual on the door placard).
2.) Turn the ignition switch to OFF then press and release the brake pedal.
3.) Turn the ignition switch from OFF to RUN (engine OFF) 3 times, ending in the RUN position. Do this within 10 seconds.
4.) Press and release the brake pedal.
5.) Turn the ignition switch back to OFF.
6.) Turn the ignition switch from OFF to RUN (engine OFF) 3 times, ending in the RUN position. Do this within 10 seconds.
7.) The horn should sound letting you know the vehicle has entered into TPMS relearn mode.
8.) Place the top of the TPMS triggering tool against the sidewall of the driver’s side front tire in the location of the valve stem.
9a.) If using a VT10, hold down the left button of the VT10 triggering tool for 10-15 seconds. The vehicle’s horn will sound letting you know the sensor has been learned.
9b.) If using a VT15, press the left button, wait until the horn sounds, then press the right button to turn the tool off.
9c.) If using a FORDTRIGGER, press the center button. The vehicle’s horn will sound letting you know the sensor has been learned.
10.) Once the horn sounds, move on to the passenger side front tire and repeat the process. Each tire should only take 30 seconds or less.
11.) After the passenger side front tire has been learned, continue on to the passenger side rear tire and finishing with the driver’s side rear tire.
12.) You may now turn the ignition to OFF. If the horn does not sound, the sensors were learned successfully. If the horn sounds twice, then the process must be repeated because there was a malfunction.
sensors can be reused,rubber tyre valves that attach to sensor with a screw, i asume its ford dealer supply
Yep so it's the rubber tyre valves that I need!! Can't find them online anywhere
What year is your fiesta?
What year is your fiesta?[/quote
2015
Ok, ford part no for valves are 530064 and there just under £8 each from ford. Thats for the rubber valves
Thanks! So would I have to go to a ford garage to get these ordered?
Looks like it unless theres any on ebay etc
Can't find any online so I'll need to go in
