Crankshaft Oil Seal Needing Replaced
Hi there has anyone ever done a crankshaft oil seal on a ford fiesta st150 how hard is it and what is envolved.
The seal is easy but you have to take the gearbox/clutch and flywheel off to get at it.
Assuming its that end, the one under the pulley is easier!
Ye it definetly is the gearbox end the oil is dripping out the hole on the bottom of the clutch casing.
Found out i have a hole in the gearbox from clutch housing so the gearbox is getting welded and clutch and all seals getting replaced mechanic found a bolt in the clutch housing which has been rattling about he has checked all bolts and there all good so doesnt know where it has came from but all is good and should be sorted by saturday
