Clutch? Gearbox? No Idea...
Hi all,
I've seen topics similar to this around the forum which has given me the idea of replacing the clutch.
I have a fiesta Mk5 1999 Zetec 1.25 and not so long back I did a stupid thing of wheel-spinning the car on dirt/gravel to set off. Within the first gear change, it felt stiff, would not budge unless forced.
I pulled over and noticed the car was behaving out of the ordinary. The sound of the engine had changed to a rumble, and with the clutch down (engine on) it was almost impossible to put the gear stick into any gear. If I put it into first, it would creep forward with a few jumps as if I hit the biting point. Whenever I did hit the biting point, it took an aweful lot of revs to get the car going.
Eventually when I got some speed, enough to make a gear change, the changes were unbelievably stiff, it had to be forced.
A few days on, it behaves as it should, even with the clutch down, other than the heavy vibrations/jerk when moving off in first gear. There are heavier (or more noticeable rather) vibrations than normal from neutral to getting going. There's also a noise from my engine which sounds like a rumble, similar to that of a spark plug being out (however I've checked them and there okay).
As said, looking around at similar faults its been advised to have the clutch and bearing replaced. I am open to other suggestions too.
If the clutch is on the go ahead, what's the difficulty on it? I'd rather do it myself and save money. Haynes manual recommends a mechanic gets to it and has the car on a ramp... Something I haven't got!
Cheers for the input guys.
How many miles has this beauty done?
75k. And it had driven so calmly too up until that point :(
Clutch could be the problem if you don't know the service history, sounds like its dragging.
