Wont Start
good evening all
I have a 59 plate fusion and this morning shortly after the car was taken for a drive i tried to start the car and it was just cranking over.
I checked the basics and called the AA
it turns out that the coil pack is not getting power
we went through all of the fuses and swapped the relays over and still the same
the power was check on the fuses on the back of the battery and all was fine
any help would be great
am i missing something? has any one had this issue?
Have you plugged the Computer into a ODB 11 scan tool? I had a no crank no start scenario with my focus and that really confused me so i brought a scan tool from Amazon and after plugging in it i had codes and a cure.
Good luck.
Yes the AA man plugged his computer into the car and it found no faults or errors.
also tried one i have purchased and the same results.
He went through a massive amount of checks and narrowed it down to the coil pack not getting power
Could it be the coil pack itself that's stopped working?
Your problem was a topic for discussion with a friend of mine. He said if the low tension side of the coil is not getting power then the HT side would be effected causing a no start.
Hope you find the problem soon as ive had a no crank no start problem which baffled me for quote a while. Now cured.
Good luck.
The attached might help and should be accurate.
The connector C800 is by the NS suspension leg going to the coil pack pin 2.
pwr.pdf
thanks for the reply
Certainly worth a look
I have an auto electrician coming out today
thank you for the reply i will let you know what they say
So the result of the call out today was that the crank sensor was hanging out
the guy who had a look said he tried to tighten this but was un able to
i was not there when he was looking at the car so i am not sure where the location of this is
any advise please guys
Did he say why he couldnt tighten it? The bolt kept turning or bolt was tight and sensor still moved? If the later then its gearbox out time, the housing the sensor fits in is bolted from behind and access to bolts is only possible with gearbox out.
Here's the location B43.
Just wondering if the AA man damaged the sensor as it would be the first place to look !
B43.pdf
thanks, i removed the sensor and it is dead.
I will replace this tonight
i checked out what i was told about the sensor being loose and he was correct.
the bolt was fully tight but there was a couple of mm of play
I will take a closer look at this later on, it is almost as if it has the wrong bolt for it, one that is too long
When you say its dead, has the end of sensor been damaged ?
yes it has
there is part of one side of the sensor missing
The cylindrical part of sensor? sounds like its gone forward in to flywheel, the same will happen to new sensor
Just screw the sensor bolt in without the sensor and try to push /pull bolt. See if the housing it screws into moves
ok guys will do
have you managed to sort the crank sensor out?
  • 1 month later...
sorry for the late reply, yes this has been sorted all is up and running with no issues
