Footwell Lights
Purchased a couple of red W5W bulbs from ebay to replace the standard white ones but they don't work. Do you need Cambus ones?
take out the led bulb and rotate it 180 degrees then plug in again.
led are fixed polarity only work when positive is positive
Fiesta's like most ford models don't use a canbus system. Flipping the bulb round should do the trick, if not the lights might be damaged.
Ok thanks will try that :)
Red standard bulbs
Tried turning them around but still nothing. Might need to get just standard non LED ones I think
Unless you have two bust bulbs arrived...
