Electric Window Stopped
Hi
My drivers door window will only go down about 6mm then stops, it will go back up
have tried it a few times but still stops at the same place.
Anyone got any idea what it might be would be great
It is a 63 model would this be covered by warranty?
Thank you
Is there frost around when you tried it? I've had this on my last car, I'd scraped the ice off the window but the mechanism was still bogged up. As soon as it warmed up it was fine
What is the date of registration of the car? It'll be on the log book or ford etis
If less than 3yrs it'll be covered if you still need to take it in
It will be covered under warranty assuming it isn't caused by user damage/neglect (can't see it would be).
Are you trying to use one touch, or does it not go down even if you hold the button fully down?
Hi
Its started working fine again there was some ice the day before so could have been the prob.
Thank you
