Help
Tight so basically, recently when I change gear slowly and have a little bit of gas on, there's a really loud squeaking/screeching sound from what sounds like my clutch.
Does anyone know what this is or if it's a bad thing?
This is in the completely wrong section.. moving to The correction section
Could be a loose auxiliary belt.
The clutch is at the other side of the engine bay to the belts though, that's all
www.yorkshiredetailing.co.uk - approved resellers of the Highest quality Detailing & Valeting supplies
From hoe you describe it, sounds like the release bearing for the clutch.
